SignUp Now!Welcome to the world where people dont like you for doing somthing they cant.It would seem that for some reason certain sections of the RX7 community won’t accept the 4.65 100-200 Dragy run was just 19psi.
For that section of retards here is a log file clearly showing the cal setting of 2300mb (absolute) equating to 19.35 psi gauge pressure as shown under BOOST column.
It shows rpm, vehicle speed in KPH and more importantly at the top section in the middle of the log you can see the Syvecs GPS recorded time of 4.65s covering a distance of 197metres which just so happens to match the distance covered in the Dragy run. (Bottom pic)
So not only did the dog shit £100 Dragy GPS record the time so did the £900 Syvecs motorsport grade onboard GPS.
It even shows EGTs, timing, inlet temps - the whole run basically, nothing to hide here.
Looks familiarCDI boxes also mounted safely now too.
Need to tidy the wiring up slightly too
I hope soIt will be better with the bracing and that sump pan will also help.
Be careful you’re don’t strip 3rd before fitting the above though mate.
I’m surprised know body had made a billet case for them yet
You read the whole thread ? Fair play to you mate, it’s been an epic ride thus farFuck me great work Mark! They was one hell of a read and a journey.
Keep up the great work![]()
