Yup the WHOLE thing 🤣
Done it on the supra forums find a good thread get the coffee on just set the autoscroll 🤣.
After reading it all I'm in two minds wether to pull the keg and either tear it down and check it over replace the seals or "just send it bro"
Get your tune checked and spot on and just send it. If only I had done that I wouldn’t be balls deep all these years later 😂
It's on a Apexi FC so there is only so much I can check.
Would really like the cable to plug into a laptop but at 400 sheets not happening 🤣.
The car has 550 primaries and 870 secondaries but without pulling them I really don't know.
I struggle to see the explanation of the twisting casing
Why would it do it only with the OS gearset. Surely it would be doing that on the OEM gearset.
I agree Joe, I think it’s a gearset issue or issue with the assembly.
It will be removed next week for inspection .
Colum will remove gearbox these next few days and Geartech are going to collect and inspect for me, I am actually hoping they find something obvious, I have noticed that during normal driving now, second gear is a bit notchy which I don’t think should be the case based on all near OEM synchros.
To beef up the casing as this is what OS Giken claim is the problem (case flex) I’ve purchased a chunky gearbox brace/bottom case from Billet rotary is AUS, Geartech will fit following their inspection.
It certainly looks the part, big chunk of billet, nice and shiny and pretty girthy 😉
I’m going to have the diff bushings swapped out too in order to help with any potential play. Pretty certain they will be stock diff bushes so likely seen better days.
I went with Super Pro, will do the whole car over winter months as have a full kit.
A few years ago I purchased a custom diff brace from Colum but never had it fitted so today it was finally installed. Looks good 👍
The final part to the puzzle is an actual gearbox brace at the front of the car too so I’m hoping as a combination this will fix the jumping out of gear issue and in turn save me having to invest in a complete gearbox swap.
As a backup I did pick up a 8.8 rear diff and alloy prop if I do go down that route.
Will report back in a week or so hopefully with a working gearbox.
Gearbox has been opened and fully inspected. Nothing super obvious found, a few “load bearing” marks as they put it on 3rd and 4th gear but nothing that would indicate why it’s popping out of gear.
They have pre loaded the detent springs tighter which I’m hoping will help.
Along with the brace pan, diff and gearbox brace plus new engine mounts and diff poly bushes, hoping this fixes it.
Peter makes a valid point though, he had the idea of getting the OEM box made in steel. A much easier task these days with 3D scanning and multiple Chinese companies for hire. Might be a consideration vs spending £10k for a full diff and box swap. I will investigate.
