Nickgreen700
- Sep 4, 2023
Great thread, lots of good info in here
SignUp Now!Not against engines swaps by the way but why not one leaderboard for swaps and another for rotaries.
āThis helps us build and learn from tested and verified setups.ā
Whilst I agree with your sentiment of sharing information to help one another improve and to learn from one another mistakes, Iām not sure that whacking a ācheap K20 in as Iāve failed with rotariesā can be classed as a āverifiedā set up.
Whats your point? I've been using this stuff for a good few years and if you had a certain level of intellect, I dont mean to be rude, but did you know that I know how it's made and still chose to use it for pure convenience?NGL before this I thought you had a certain level of intellect, and then I saw you have purchased Devilsown brew, I don't mean to be rude, but you know that's Literally 50/50 screen wash right? The colour is a dye?
Most screen wash is like 40-50% methanol anyway if I remember right?Whats your point? I've been using this stuff for a good few years and if you had a certain level of intellect, I dont mean to be rude, but did you know that I know how it's made and still chose to use it for pure convenience?
Also I used it on todays dyno session for some of my base pulls
1. it worked great and in line with expectations, my data confirms it.
2. it is super convenient.
3. I've got nothing negative to report.
Let me guess you would rather people use 50/50 screen wash from Tescos?![]()
It's really not the same thing mate! Buy cheap buy twice! That's how the story goes.Most screen wash is like 40-50% methanol anyway if I remember right?
Yeah I know that I just mean the content is actually quite surprisingIt's really not the same thing mate! Buy cheap buy twice! That's how the story goes.
There's significant differences between screen wash and 50/50 water meth mix.
Composition of both are wildly different:
Using screen wash instead of a 50/50 water-meth mix in an engine specifically designed for the latter can lead to engine damage, reduced performance, safety concerns, warranty issues, and efficiency loss. Now for most FD owners, reduced performance (or sometimes no performance) is the story of our lives! We hardly have any safety concerns and warrranty? (lack there off). In terms of efficiency loss...we don't have great efficiency to begin with compared to the latest and greatest..which leaves only one (major or minor) issue depending on how deep your pockets are, engine damage!
- Screen Wash: typically contains water, a mixture of detergents or surfactants, and some antifreeze compounds. It is designed to be safe for use on glass and painted surfaces and not designed for use inside internal combustion engines let alone a 13b.
- 50/50 Water-Meth Mix: is a specific ratio of distilled water and pure lab or race methanol, with a food dye for the colour so you can do a quick visual check of how much you have left in the tank. Often used as an anti-knock agent and for cooling in high-performance or forced-induction engines. It is not meant for cleaning surfaces and is not safe to use in the same way as screen wash.
To each their own, use whatever you want in your build. At the end of the day, if someone uses screen wash as a cheap substitute, then on the balance of probability they are very likely to also be cutting corners in other areas of their build, such as using cheap spark plugs etc etc... This can lead to engine failure, which unfairly contributes to the misconception that certain engines like the 13B are grossly unreliable.
I meant wouldnt*Yeah I know that I just mean the content is actually quite surprising
By all means I work in a professional background and would recommend it to any of my customers![]()
How much or how little you prep will depend on the confidence you have in your 7. For me the 7 had weathered all the draggy pulls over the years, turning each challenge into a victory lap. So I gave it the royal treatment with the usual oil and coolant change, topped off with 8-10 draggy pulls and a quick 1hr dyno sesh to make sure all systems were a go.Very cool trip, would love to do this! What level of spares did you take? Did you have a plan for any potential catastrophic failure?
Dont over think it...just do it when you are ready!What an incredible trip, thank you for sharing the photos. I'd love to take my RX-7 to the Nurburgring but have to admit I've been a bit concerned about reliability - maybe one to investigate further once the AC is functioning!
