February 2016
Yesterday, I took my car to Essex Rotary to have some cheapo but effective neoprene radiator ducting fitted to seal below and seal the sides of the new Koyo radiator, modify my seat rails, and mount my water injection pump on the car because I didn't know where to put it given the lack of space underneath my car due to the factory engine bay, A/C, power steering, etc.
Pics of Koyo Radiator Before and After Ducting
Before Ducting
After Ducting (but before undertray was put back on (which shows ducting and sealing better)
Seat Rails
On the driver's side we followed Dark Knight's How-to and removed the Japanese stopper to extend the rails to the UK, US and AUS spec which is 3 clicks before full lock. Then we took out the second stopper which moves the rails to the end of the adjustment range. We determined that the adjustment sliders are not in anyway structural and thus the rails themselves are still just as safe as they were before the modification.
On the passenger side I only modified the rail to UK spec since that will be fine for most people as I felt comfortable with the Japanese rail when I sat in the passenger seat and I am 6'2".
We even touched up the rails to make sure they were all black unlike in the below photo.
As for the difference, HOLY CRAP it's amazing. It's now much easier to get into and out of the car and the driving position is way better. My legs are comfortably stretched and in fact the clutch pedal is now too far away if the seat is all the way back! I have tons of more leg room, can heel & toe and I can see all of the gauges and the entire RPM and speedo gauges for the first time without dipping my head! All I need to do now is get a snap off steering wheel boss to bring the wheel a tad closer to me as my arms are pretty stretched out now and I prefer to have them bent slightly.
Water Injection Pump Install
The main reason I brought this car to Aston was to find out where and how to mount the AEM water injection pump in the car so that it would still be level and/or lower than the bottom of the windshield wiper reservoir tank that I will be using. Unlike a lot of other guys that run water injection in the FD, my car is still completely stock in terms of engine bay configuration with power steering and A/C (both of which I will never remove) and thus it was difficult to find a good spot. What made it more difficult was that I didn't want it installed in the back of the car near the rear washer bottle as I didn't want the pain in the ass of wiring and running hose all the way to the front.
I saw a How-to on the American forum for installing the water injection kit to the chassis rail on the passenger side near the spark plugs. Unfortunately, that How-to involved fabricating a bracket and welding it to the frame which we thought might be tricker than the guide made out given the lack of space. However, Aston applied his mind and figured he could use the stock AEM bracket to screw it into the frame rail. He noticed that two of the four holes in the bracket exactly matched holes that were already in the frame, and for the other holes on top of the pump he could basically tap the frame and thread it to match.
Tapping the frame and making the right threads turned out to be a royal pain in the ass because of the lack of space in there but somehow Aston managed after a couple of hours and we had the pump bolted to the frame using the stock rubber anti-vibration stoppers! The pump sits pretty close to the spark plugs but they seem to still be accessible if a bit more difficult to access. I really like it because it is very discreet and it is mounted about level/slightly below the washer bottle. Check out the photo below to get an idea of where it is. The oil you see is from spilling when doing oil changes and isn't a leak in the sump or anything.
AEM 250cc/min Nozzle Tap into Throttle Body Elbow
It was getting late and the sun had already set so Aston couldn't finish the water injection install today, but he offered to at least tap the throttle body elbow, create a 1/8" NPT thread and route the 1/4" nylon tubing from the nozzle to the pump below. This is actually alright because all I need to do now is drill two 7/8" holes in the washer reservoir for the self-sealing feed tap and the self-sealing leveling sensor before tackling the electrics which I am pretty comfortable with doing on my own.
We debated for a little bit on where to tap the elbow and decided it made more sense to tap closer to the intercooler rather than closer to the throttle body. We took off the elbow and the pipes were shiny with oil but what can you do? It doesn't really affect performance so I'm not too fussed about it, although the perfectionist in me would like to drench all of the pipes and intercooler in brake cleaner and dry it all out...
Below is a photo of the inside of the throttle body elbow with the nozzle tap and another photo of how it looks in the engine bay.
Overall, I'm very happy with the ducting on the radiator, I love the extra leg room from the seat modification and I'm stoked about the water injection pump location and location of the injection nozzle.
I've used Aston a few times in the past when I had my RX-8 and he has never dissapointed. Aston exhibits very good attention to detail and good creativity, in particular when figuring out a way to mount the water injection pump. I'm very grateful for his assistance today and would recommmend guys in the Essex/London area to pay him a visit if you need some work done. It is also nice that he has access to some very hard to find parts such as Idemitsu oils and premix, R-Magic, Greddy, Cusco, Racing Beat, Royal Purple, Carbon Cooling, Competition Clutch, Black Halo Racing, etc in which he has direct trader relationships with these companies to import and sell products throughout Europe.
