Managed to start my engine for the first time- engine was built and then stood for a LONG time. Can get it to start and idle with a bit of persuasion on the throttle, but oil pressure is worryingly high- the ecu is saying it is out of the top of the band, and it is causing oil leaks. Before I start thinking of engine rebuild is there anything I should be looking for? Have considered incorrect sensor calibration needlessly causing concern but I believe it is correct. Can the oil pressure regulator be changed in situ?
