Its 5 bar at cranking though, so once I get it actually running it will be off scale. If anything the readings have increased since changing the oil (sensor actually reading closer to 7 bar), but i have also replaced the sensor line with AN fittings rather than push fit so assuming I have less pressure loss in the line. There is plenty of oil getting to the turbo so feeling content there is flow there, Is there a way to confirm flow to the rotors without pulling the engine? The last readings were taken with plugs out to see if there was any kind of passing between rotor housing and oil system- made no difference so I am sorta happy it isnt that. I guess it 'could' be clogged with assembly lube etc, but would think I have flushed that through now.
