Twin Turbo Intake Setup
Joe do you know if you can replace the dump valve one with an actual dump valve. Thinking sard/blitz etc
not sure mate, I don't see why not as they do the same job, although I never bothered as it's already there.
Yes I thought the same just wasn’t quite sure how I felt about just a pipe poking to the atmosphere when it used to essentially recirc.
I had one of these and you can use Land Rover discovery filter (46798) although I think they are slightly thicker. If not a k&n filter 33-2119
Yes mate, any bov with the right hose end will work just the same. Just make sure it's the black one at the front instead of the brown one near the firewall.
Cheers mate.. been checking some prices and they’re not as cheap as I’d thought considering I’d need 2 (£50+ each).. Nengun do 2 of the ARC Filters for just over £100 plus shipping, just not sure how much shipping would be as I also need an FC Commander that they also do. So could combine the 2 orders to save on shipping cost ?
Is the general consensus to stick with the ARC box rather than look around for something like the Greddy or Apexi setups?
Is there any harm in replacing the rear (brown) one? I'm trying to hunt down intermittent boost leaks & think that the factory DV might be the culprit.
@Cullen94 i'm looking at a similar set up to you and Roy on my 99, Odula snorkel with Autoexe intake (where did you get yours? seen some varied pricing) and a SMIC that will let me keep the stock battery location, i do have a smaller odessey PC1200 battery from my previous 7 so can spare some room
