Also worth mentioning that before I started the radiator and intercooler I fitted AEM coils using the DM Motorsports relocation kit and loom. This is the problem with going back in time to bring a project thread up to date
A little fiddly to do with the Power steering still etc still on if you have the hands of a grown adult and not an infant pigmy but got there in the end and it all fits nicely and is easy to install, if you have any queries on installation then Tom (Advocult) has done a cool video on his YouTube channel to guide you.
Next up on the radiator was to plumb in the coolant hoses, this was the trickiest part. I'm sure most of you that have gone single turbo will have re-routed the old heater matrix pipe, well I had to here:
However whatever way I tried to route the coolant hoses to the radiator they either clashed with this or the pulleys close by, so it had to go, not a great tragedy as I was not completely confident with the joins in it anyway but that means I will have to look at another route for it to the bulkhead.
The kit comes with the hard pipe that fits between the silicon hose for the radiator and that has a pipe off it for the AST, as I have now no longer got this I used a Dremmel to take off the rolled lip on it and used a plumbing compression stop end to seal it up.
I then bolted in the ducting around the radiator, there is foam insulation tape supplied with the kit so help plug any gaps to make it as airtight as possible for better flow onto the intercooler. Once that was done I could get the intercooler on.
I then connected up the outlet pipe to the elbow to make sure everything lined up properly, the JDM tyte yo Greddy silicon joiners are being replaced with more purple silicon to keep it inline with the rest of the bay.
I had the turbo back from Turbo Dynamics by this point so I tried that on for size.
