It appears that my clutch is on the way out, 3rd gear onwards it will slip from 3-6k revs then reengage. Clutch and gearbox were replaced about 7 years ago by previous owner so would've expected it to have lasted longer as it's not often used.
Since the clutch is coming out I am thinking of putting in a lightened flywheel as well. Are there any recommendations for what parts I should look for?. I am running a fairly stock FD and will be for road use only so needs to be usable.
