Pleased to say it is now all fixed. It is looking like it was a combination of issues that where the cause, along with the initial stolen PFC & blow off valve.
- Replaced Soldnoid control box with new item due to bad relay
- Replaced all old / brittle / cracked lines
- Installed old removed Evo Blow off valve to replace stolen item
- Renewed O'ring in Y pipe/
- Lubed and reset charge control arm / wastegate arm.
Had a short road test and it all works as advised but is boost spiking to approx 1 bar on stock ECU so new Power FC and tune for it now.
