- Jun 30, 2020
So I've installed my own IAT sensor just before the throttle body. Its a common GM IAT sensor, calibrated by myself. The values correspond to another temperature sensor I have in the mouth of the vehicle for ambient.
The stock sensor lies - by a lot. At cruise, anywhere between 9-12c delta between my new sensor on the elbow, and the stock location, "fast reacting" iat sensor on the manifold underside. Just to be clear, the stock IAT reads well above my sensor.
Now there is a very slight difference in location, about 6 inches or so. But the different values are too high for the location to be the cause of this. I would personally put it down to the stock location being a heat soak prone material (metal), installed in a heat soak prone material (metal manifold), installed in a heat soak prone location (under the manifold). All sensors start out at ambient on engine start, but the stock IAT is diverging within 5 mins.
I see around 3-4c delta between my ambient temp sensor and my new IAT sensor. Until now, I was under the assumption that I have a 17c delta from ambient to intake. I've not done many harder pulls yet because I need to clear out the tank of meh fuel first, but still. Dont trust it! And if you have a custom ecu which uses that sensor data - maybe time to install a new sensor?
