- Jun 28, 2018
That’s a beastly turbo, I’m hoping to be revving as high as 9k when mine is run in and mapped.
I couldn’t resist, started buying some carbon bits for the M3 today.
All the boost, all the timing, all the rpm
SignUp Now!That’s a beastly turbo, I’m hoping to be revving as high as 9k when mine is run in and mapped.
Not updated this in ages. Had a issue with the car not making any power on the dyno which turned out to be a sticking wastegate and a few other small leaks discovered by stu and jay. I left the car with them after it played up on dyno and got a lift home with @Robbo80 as I couldn't be arsed to deal with it myself lol.
Engine has still done very few miles so only tuned very conservatively to 1bar and a 7200rpm rev limit making 440hp. Also my exhaust is now a restriction as the bridgeport wants to breathe lol. Going to fabricate a exhaust at some point 3.5" turbo back then in the new year up the boost to 1.4 bar and a 9000rpm rev limit once I have a few more miles on the engine. All the ID I injectors etc are also now fitted and my FEED elbow for maximum jdm points. Just need to fit the black silicone to replace the ford focus blue lol. Car is pretty much finished and how I want it just the exhaust and map to do and also fit all my poly bushes and pillowballs that I have been putting off for months and also paint the light cover that removed itself from the vehicle at the national speed limit.View attachment 18168
Also bought a new daily driver for anyone that might care(unlikely) View attachment 18167View attachment 18166
Ah don't get him started! There's not a day that goes by where he don't shut up about his tankI've noticed quite a few of us FD owners have M3s. That's a lovely F80 M3. Take one of em to stage 3 with a littco hybrid turbo and you making insane power and torque!
Yeah they are a perfectly daily driver that's reasonably fun cant really fault the car tbh its highly capable plus Nigel absolutely loves it. Win win
What was the issue with the 8374 on your build? What was the reason for the larger unit?
It's more of a low to mid range turbo, I'm wanting something that will flow more air up top.
Do you have a boost / AF:R graph from the 8374 tune? Were you on the biggest exhaust housing for the 8374?
Can't wait to hear this fire up!!!! (I'll open the window in the kitchen see if i can hear it from my house)
It wasn't bolted down in this picture. There is a good bit more room. That was just checking it fitted lolHow does this work when you rev the motor or go into a left hand corner and the engine moves?
Hockey puck engine mounts used to be a thingHow does this work when you rev the motor or go into a left hand corner and the engine moves?
Hockey puck engine mounts used to be a thing![]()
It'll be alright. Like hammering it into place something will bend over time then it will all fit nicePretty sure the engine would still move.
It'll be alright. Like hammering it into place something will bend over time then it will all fit nice![]()
