Fluctuating Idle (not high, leaky primary injector?)
Mat153
Making this post in a last-ditch ideas effort before tearing into the rats nest when winter arrives. Pretty sure is a primary injector leaking but don’t want to risk disassembling the rats nest if I can help it. I apologize in advance for the essay...
Problem Statement:
Idle seems rough when dipping down to ~800rpm but oscillates 50-100 rpm at about1.5-2hz. Its noticeable enough to vibrate the car. Further to this holding revs at 3krpm stationary is fine for a couple seconds then starts to break up a little similar to how the idle oscillation comes on. Additional symptom is poor fuel consumption (best case estimate 20mpg motorway, average calculated around 16mpg including some local and some motorway driving, uk gallons). Also about a 30% rate of an exhaust pop during shifting around 3k just gentle street driving. Occasional pop when the cold high idle/cat warm up disengages too.
I am almost certainly being a bit too anal about this and could just raise the idle and be done with it, but it would be nice to not burn through AS much fuel on longer trips and in case the catalyst ends up shitting the bed because of the popping.
Background info:
Engine etc is completely stock 99 spec, bar an RB cat back and BUR9EQP plugs all round. Seems like the car may have sat for up to 10 ish years prior to a couple years ago. Fuelling issue corrected last year with new pump and filter prior to my ownership. Car runs and boosts fine on throttle, cruising etc. just the consumption is high. Cold starts fine, hot start occasionally stumbles around 500 but after a touch of throttle to get it above 750 it gets into the oscillation and remains there or higher without issue. Idle screw is likely a little out as it acts ever so slightly differently each time adjusting. Compression checked last year in the 7s all round.
FSM troubleshooting from F-178:
Rough Idle when warm (could just be oscillating coming across as rough though): PRC Sol Valve, Fuel Thermosensor
Idle Fluctuation/Hunt: Idle control valve, Primary injector, spark plugs, ignition timing
Fuel economy: Air cleaner element, Primary injector, fuel pressure reg, 3-way catalyst
The only repeat cause is a primary injector so leaning towards that.
Actions taken so far:
Throttle body readjusted (lower plate adjusting screw was slightly open instead of shut). Plate adjusted until TPS stopped receiving changes, then increased 1/8 to 1/4 turn so its not completely in forced contact with the bore. Also adjusted the throttle cable with a little bit of slack just in case. TPS then adjusted back into position, narrow band dead on 1V, wideband 0.53v to 4.32V (struggling for memory on those but slightly above and below nominal respectively). Thermowax working fine too.
Then had fun readjusting the idle set screw. With high idle it does not oscillate but a bit of intermittent burble. During adjustment I could get the car to stall out closing the adjustment screw, and get it over 1.2krpm so pretty sure there are no vacuum leaks based on that.
It is smoother (no oscillation) when the test pin is connected to stabilise the IAC valve etc. (may have seemed slightly rich though still but not entirely sure) After an ecu reset it was quite smooth for a bit including testing with the IAC valve disconnected, went for a drive and it was back to oscillating. Not switched the car on since that but want to try disconnecting the IAC while its oscillating to see if it instantly stops it.
IAC valve has been removed and cleaned (only a touch of surface soot in the output side and after some carb cleaner looked new. Valve was seated with a bit of preload but some pulling on it starts to open it too so not blocked. Did not apply voltage to it to test actuation though.
New O2 sensor in, identical symptoms before and after the change.
Rotor 2 plugs look fine (about 1-1.5k miles old). Been too lazy to get the front rotor plugs out just yet, but need to at some point.
MAP sensor readings (engine cold and off) are within 0.07V of nominal scaling. Used disconnected vac pipe and a vac pump and gauge to test without unknown engine vac level.
No engine codes, did have a code 56 a while back but cleaned the exhaust ground up as a precaution and seems fine now.
Ran some BG44k through it too, one can to 1/8 tank and let it sit a few days, one can to ¾ tank into normal driving as has been recommended in one or two places. No change in behaviour beyond what could be attributed to the variation I get.
Fuel pressure (incoming line from firewall has a gauge in place) depletes to zero pressure within 24hrs (want to check it over shorter periods too for more data) of shutting the car off. Normal 2 and a bit bar when running otherwise.
Think there may be one or two things I’ve done but forgotten about, and my apologies again for the essay. Any input over the next couple months would be greatly appreciated, TIA.
You running a stock ecu?
Worth doing a smoke test I have a tester if your near Northampton but sounds like you’ve have cover most things just get them injectors out and tested, you can update the rats nest pipework while your there as it will certainly need doing if it hasn’t been touched (it’s easy enough just go careful pulling stuff apart)
Yep stock ECU.
I may take you up on that sometime as im only in Milton Keynes.
Was thinking of doing all the hoses at some point. Ive found a supplier for most of them, just cant find somewhere for the 3.5mm ID hoses yet.
Silicone will stretch so I wouldn’t worry too much.
Ment to say what happens when you disconnect the IAC this would leave just a mechanical fault and nothing else should really make idle fluctuate
I have but it was just after an ecu reset and not all the way up to temp so was not fluctuating at the time. No fluctuation with it unplugged and seemed slightly smoother but still a little rich. Need to try it when i catch it fluctuating heavily some time. Thats the plan for this weekend.
Found some 3.5mm so all vacuum lines are on order now regardless.
Got round to it last weekend. One video before unplugging iac, one unplugged, then two with it plugged back in after. What's completely thrown me off is the idle being higher with the iac unplugged as in theory it should be getting less air. Besides that it did make it significantly smoother.
I've got replacement hoses so part of me is thinking tearing it all down and getting the injectors cleaned and tested regardless to be honest.
I would go through this guide, if idle is high with iac disconnected it will be an adjustment or leak somewhere
Kind of abandoned this thread while the car was off the road for the winter as i got the injectors out for testing and refurb, and replaced a bunch of vacuum lines and gaskets whilst i was there. Thank you very much for the advice so far.
I have finally gotten round to smoke testing via the throttle body intake elbow. I've got rather large leakage from the TB which is presumably the elusively sized x-rings, but what has concerned me a little more than that is a few moments later i got smoke coming out of the intercooler outlet pipe that was disconnected. The only place I can see this happening in the 12/95-02 diagram modified by Ceylon is notated (A), but unsure if that actually connects the y-pipe to the housing where the smoke could get through from the intake. Hoping someone can say if its normal or not.
I suppose the one positive is that I couldn't see any leaks from any vacuum lines or anywhere else so it could be worse!
Can I ask have you checked the air adjustment screw under the throttle body you access it under the inlet elbow. Its surprising how many have been messed around with.
I would literally do this first just wind it all the way in then wind it out normally about half a turn or there abouts. Its basically an air bypass screw for idle that allows more air past the butterflies without effecting the tps or butterfly position.
I would do this then disconnect the iac and set your idle on the idle screw then plug you iac back in.
I would also make sure your dashpot is working just incase when you've been for a run then rake your foot off the throttle its not and it causes the fluctuations because the idle drops to quickly.
Can I also ask do you run it to boost and thrash the balls off at least once every journey once its all hot. If you dont do this you can gum things up inside the engine inc the spark plugs which can easily cause idle probs.
Also these cars dont really like a low idle I would be aiming for 850 to 900 all day long the difference in fuel use is minimal but the car will be happier with a little more revs
Hi,
Idle air screw I tried adjusting a few times last year after resetting the tps and minimum throttle screw, but was getting inconsistent results (both with IAC valve unplugged and with the relevant pin shorted in the diagnostic connector as per fsm). Lowest idle I currently get is a hair above 750-800 so about right, but varies and bounces a little still like the prior videos. Idle raises with load from fans, a/c, etc too.
I no longer consider the fuel consumption an issue as I've read that open loop/closed loop threshold is 3200rpm where initially I had read elsewhere that it was 3800. Dropped the cruising speed on motorways to 3150rpm (previously about 3250rpm) and mixed fuel consumption is now 23mpg so about right. Normal driving and full chat it runs without any issues.
Dashpot seems to be working fine just moving stuff around by hand. It catches idle smoothly coming off throttle too, never had it stall after coming off throttle. Spark plugs are now brand new and no change in behaviour compared to the old ones, I make sure to give it a good send once in a while (possibly more than i should to be fair). It's purely a weekend car so very little opportunity to clog up (also owned an rx8 since before getting the fd so know the drill) .
Seems like the main issue could be just the throttle body leak at the moment, the intercooler pipe has me a bit confused though.
idle rising is correct. i expect you have some smoke working way back through the vac lines of the turbos where something is letting by.
i would also just set the air screw to where its supposed to be and leave it
