Ferrox’s 92 Cursed Nightfury track show build
So after all the messing around and the booth going off! I finally have a bumper painted! also fitted my Rx lights taani’s we have finally got somewhere! So happy to have it at the starting point! now I can continue with getting ready for hillclimbs!
Birthday midweek trip to C & M, crashed the German show and got a decent spot, suppose the engine was designed by a German engineer so it’s still fitting
Not overly much to report, Bought some dress up bolts to make up some missing uniformity with the spoiler, changed over the purple to blue. And also removed the horrible crusty bolts for the new stainless domed with black nuts to finish it off, everything looks right now!
Finally got round to removing cruise control, as it was annoying me and I didn’t/ can’t use it anymore. Gives me some more space.
As I’ve found it hard to find any guides online which give you a run down, here’s a brief one for fitting a fuel tank baffle - we start at this hatch!
You’ll have to remove the white multi plug, and this earth here, can be a bit tricky to not break, it’s a push down where I’ve circled here. Pull it off and then clean up the contacts
As you can see the Earth here is corroded and the bolts aren’t much better, I’ve been having an issue with my fuel level not reading full and believe it or not I wasn’t driving haha.
I just marked the pipes to make sure not to switch it over. Remove the screws and clean the contacts to make a better connection and hopefully sort out the fuel gauge.
Next, before opening the tank, remember to blow off all the crap out the way so it doesn’t drop into the tank 😂, also blow off everything that’s going to be in the area
