SignUp Now!I've got some data on how it performs on a piston engine...but that does not translate over to rotaries. Should have some results soon!Interested to see how this performs.
Thanks mate.Just reading through your thread mate, lovely car and credit to how far your going with it.
I used to love the days when i was out in the cars all the time with my mates, enjoy those times mate!
There are different trails on thought on the timing maps and how these should be configured. I prefer to use a flat timing map on boost with a 13b engine. I am certain experienced mappers may disagree with me and advice you to increase timing as rpm increases on boost. They are not wrong as the combustion cycle gets smaller so this is something for you to consider with your tuning.Whats your timing map at? Could share a picture? Just running an engine in myself
Thanks mate, mines just on the PFC base map atm so wanted to see timing, yours is a lot more retarded than mine in certain areas iircThere are different trails on thought on the timing maps and how these should be configured. I prefer to use a flat timing map on boost with a 13b engine. I am certain experienced mappers may disagree with me and advice you to increase timing as rpm increases on boost. They are not wrong as the combustion cycle gets smaller so this is something for you to consider with your tuning.
Which ecu are you using?
Disclaimer - below is a safe place to start imo assuming you have calibrated your base timing accurately. You will need to test your timing map on a dyno to ensure the best results for your application. I would refrain from copying anyone's timing map including mine and test what works in your application.
In the example above; when dialing in the timing map on the F20c engine. Timing was removed from the base map to tune the cruise and idle areas. However, this retarded the timing a bit too much....the result was the exhaust manifold started to glow red. This makes for a mega cool photo but also a great indication that the engine wants more timing to get the egts under control.
Keep the trailing split to 10 or 12.
Sounds good. In the cruise and idle areas you should be fine if only running in your car. Doesn't the pfc add additional timing additional to the ign map as well? so that may be something for you to be mindful of.Thanks mate, mines just on the PFC base map atm so wanted to see timing, yours is a lot more retarded than mine in certain areas iirc
I think so, so been going through on a gameboy to make sure theres nothing untoward. Thanks for the heads up.Sounds good. In the cruise and idle areas you should be fine if only running in your car. Doesn't the pfc add additional timing additional to the ign map as well? so that may be something for you to be mindful of.
iirc the PFC adds 1 deg of additional timing above 4500rpm and another 1 degree above 6000 rpm. I believe this is an automated process that happens in the background.I think so, so been going through on a gameboy to make sure theres nothing untoward. Thanks for the heads up.
Checked mine last night and its very similar to yours as I thought it would be. Had some timing pulled out of it for running in the engine but was unsure on how much. Thanks for clarifying.iirc the PFC adds 1 deg of additional timing above 4500rpm and another 1 degree above 6000 rpm. I believe this is an automated process that happens in the background.
Apologies for dredging this up but I’m after a set of these and would like to know how much of a reduction to ride height is achievable with them. Some websites state 15 mm reduction front and rear - is that correct from your experience? Other manufacturers such as Tein seem to confirm that their kits (eg mono streets) have a lot more flexibility on ride height adjustment than the ohlins!?Installation, protection and ride height as per Ohlins recommended setup in the Manual. I believe the ride height is 20mm lower compared to stock
