- Feb 18, 2018
I guess you could say thatBoy you a new mapper on the block huh![]()
Mapped it to 1.2bar on the road which was extremely lively, some poo my pant moments as the car wanted to step out in 4th
SignUp Now!I guess you could say thatBoy you a new mapper on the block huh![]()
Honestly the best thing I've invested my time in during this covid downtime.Loving all the tuning updates, I've been learning tuning too (online, not put to the test just yet).
I'm nearby in Bridgend too, will have to compare notes at some point after lockdown!
I haven't got EGT's connected directly to my link ecu as I don't have enough free channels which includes my expansion loom. Do you have egts on yours?Are you measuring EGTs ?
Yes I have 2 x EGTs, one on each runnerI haven't got EGT's connected directly to my link ecu as I don't have enough free channels which includes my expansion loom. Do you have egts on yours?
However, I used my good friends plug and play egt probes for both rotors with ugly af analouge gauges in car while tuning. Thus the afrs I've chosen for my application. To some they may seem a tad rich and there is no doubt they are but they give me a safety net which allows me to run multiple WOT pulls back to back and simulate dragy gps runs from 2nd-5th much like you would on a trackday and both rotors are hovering between 890-980*C. There is no doubt I'm trading some power for the additional cooling.
Nice, have you measured what egts you are getting in the cruise areas?Yes I have 2 x EGTs, one on each runner
I used a KMS EGT box via CAN
Bridgend is fairly local dude, who are you learning with? Sure thing more than happy to provide you with some tips.
Which ecu and setup are you planning to run?
Not yet, it’s a new addition before next tuning session.Nice, have you measured what egts you are getting in the cruise areas?
Sounds good, EPA know what they are doing, I learnt my open loop boost control strategy from them. Running it closed loop is a bit more complex and you have to be mindful if tuning on a hot day for big boost applications as the same car on a colder day is asking for trouble specially if the mapper doesn't account for this.Yeah I'm really enjoying so far. I've got evans performance academy, its got generic tuning tips, then courses on specific ecu's (haltech + link), also some live tuning series (he's got one on a single turbo rx7 with a haltech elite)
Also got the hp academy wiring fundamentals course which was good too
At the min I'm on twins, with a haltech pnp kit (elite 2500) not used it yet (currently on a rich JDM chipped stock ecu )
Need to get some driving in and re-compression test it (as its low)
So setup will either be twins+old engine, or rebuilt engine + efr8374 or 362sx-e (8376 equiv)
Interested in this as well, the bearings on the efr are meant to be very effective allowing it to spool so quickly. If I end up getting a efr/sx-e I'll have to grab a turbo shaft speed sensor, as it'll be really interesting to see what it gets up to. Should be an interesting parameter to account for in the tune too.
Seems like a poor battery and some grounding issues maybe? Battery should be sat around 12.7V ish prior to cranking if healthy and not much load on it. Dropping to 7V during cranking seems very extreme.
Another test would be to pull the rx7 battery and just use the dailies and do a log. Daily battery may be struggling to start the car and have your rx7 battery trying to drain it.
Voltage drop at the fuel pump is common, have you done the direct feed + relay mod? If you haven't try and get a multimeter across the fuel pump terminals and see what voltage you get.
With the stronger fuel pump voltage, you may find you have a bit more headroom on fuelling.
