Sturneyrx7
- Jan 8, 2018
Looking good but you know, it’s gonna be boss when done! Great work buddy
SignUp Now!I'm tempted by the Rays Gram Lights 57XR in 18 x 10.5 ET12. Probably need some sort of spacer too.do you have a short list of wheels to choose from?
Getting close to seeing this all built back up and looking epic. Albeit with stock ride height and wheels that don't fit the kit at allbut I do have coilovers ready for it, I just need to figure out what wheels I want.
Go for advans, as good as volk but a few less pennies. Can get some nice widths and offsets toI'm tempted by the Rays Gram Lights 57XR in 18 x 10.5 ET12. Probably need some sort of spacer too.
Other than that it would be TE37, I do quite like Work Meister L1 as well. I'm basically open to opinions as I'm so torn and go between options all the time
I'll take a look, not really looked at any Advans before so hopefully I find something I likeGo for advans, as good as volk but a few less pennies. Can get some nice widths and offsets to
They are stamped 18x12 ET10 and they're custom made to spec, so I hope so
They will need a spacer I think and also need aligning as the toe isn't quite right. But yeah, they don't quite fill the arch.
Are your arches +65mm? As I know some TCP Magic kits had slightly smaller arches depending which kit you have
I have 265/35/18 front and 315/30/18 rear. Could have gone slightly bigger on the rear I think.Mine is a GT Kit so 65mm rear. I think the front is 35mm but I’m running the same wheel setup on the front so they might be bigger than 35 mm
What tyres you running?
That was this morning, doesn't look too bad but I definitely think it'll need spacing a little bit once I lower it some more
