FFS, when I find out who worked on this for Denny 20 odd years ago, I hope they're not still trading.
Went to change the clutch hydraulic flexi and fluid and just noticed this.
Bellhousing bolt not even tight.
So we've got:
Mixed coolant
Wastegate actuator not connected
Missed perished brake booster vacuum hose - like, the biggest of all of them...
(All the vacuum hoses are tied with little cable ties, not sure if that's normal?)
Black diff oil that looked never changed (gearbox oil was red, and seemed relatively fresh)
Leaking RTV sump seal
Two 0.9 bar pressure caps without lugs fitted, to both the AST and the filler neck
Old plugs practically came out by hand (but they're not supposed to be that tight, so were maybe okay)
Bolt missing for hardline to clutch flexi bracket
Gearbox not actually attached... well, one loose bolt for sure
These may be several garages over several visits, of course, but Denny's big complaint was a misfire when the car was supposed to be going for full power and even then I wanted to get to London and check the vacuum, actuators and sensors over systematically. I'd have found the booster and actuator but they seem like "RX-7 misbehaving 101" things to check surely?
Denny did have a moment of worrying he'd put the wrong coolant in, but he only put coolant/water in to get home /after/ it burped out all the coolant, and the gel took several flushes to feel like I'd eradicated it, got the small pipes clear etc.
But I do know he didn't do anything himself, he took it to specialists back then. Having tried to fit the E-clip on the wastegate myself I can believe that it is very easy to half-clip on and feel like it clipped, and then for it to fall off - which would align with the memory that the car worked well sometimes, then the problems returned...
