TNS Relay
JE96
After a TNS Relay as mine seems to have died.
TIA xx
Just FYI. .....you can open the plastic and clean the inside of the relay with some sand paper and that usually solves the sticky relay
Open it up and plug it in to see how the relay works. You gotta get right in the gubbins to clean it if I remember rightly!
Worth a go to save you money! Failing that I'm sure @Jit has some bits for sake! Hes really having fun stripping his black fd 😛
Panic over, didn't have power to the TNS so checked out the wiring under the arches which was horrific and took out the 15A tail light fuse. Re did the wiring and new fuse and all good! o_O
