Stock 99rs oil leak on down pipe
Nickmms94
Hi guys,
Did an oil change today nothing out of the usual but then after a drive I’ve got oil dripping/leaking onto the down pipe causing smoke. Can only assume it’s an oil feed or return because of where it is ? Any suggestions before I start taking it apart the weekend?
Not great pics but all I could get in the dark
Might not be directly above but check the rubber o-ring in the y pipe (where the 2 halves join), though there shouldnt be excess oil in the y-pipe. The oil feed pipe on the twins are sheilded from factory and closer to the engine also with the heatsheild for tubo exhaust housings below it, still worth checking. Best to take the intake pipes and/or y-pipe off to see whats going on
