Steering wheel size poll
What size steering wheel do you have? (mm)
  • Total voters
    14
Temujin
I want to update my wheel as it’s old and crummy, thinking 330 is ideal but difficult to know without trying multiple.
Wanted to see if there is a more popular size on here!
I just got a new one for mine. Got a 350mm Personal Neo Grinta, looks and feels perfect and can still see the clocks.
I’m finding 350 a bit big for me, need to feel a 330 though before I commit I guess
Also got the 350 personal grinta, goes perfectly inline with the top of the instrument cluster peak
I have (but wont be using it for long) a 320mm Flat wheel and I feel it is a tad too small for the car, I think 330 should be minimum but like most others a 350 might be best, its still a 25mm reduction over standard.
I've got a couple of 350mm's, one 5 cm dish one like 10-15 cm dish, but they both still cover some of the upper parts of the speedo and rev counter, not really ideal having to look around them etc.
The bigger dish blocks less, but with the hub puts the wheel a bit to far from the stalks, and a bit to close, I am using a quick release, could it be too much hub spacing? seems odd that the deeper wheel blocks less if that is the case etc.
I did notice the stock wheel has a kind of angle at its base where it bolts to the column.
I kinda feel they need that angle on them, to bring the top of the wheel forward to more of a vertical so you get full view of the instruments - anyone else noticed this?
I didn’t know standard was 375! I have an old momo currently, it’s very decrepit however so was thinking bout a nice nardi or something
The Factory MOMO if you peel off the centre cover, it's velcroed on has a dish to the mount although it looks like a flat wheel. Might be worth measuring the dish value and buying one similar but smaller diameter.
It’s not a factory wheel unfortunately, some aftermarket one! Looks like the personal grunts a bit
