SignUp Now!Will do thanks everyoneI personally can't see a whole lot wrong there. That said if those are original shocks then they are probably due a change. Try adjusting the shocks and see if it makes much difference.
Ok are they easy to get off? The S2000 was a bitch.That looks fine, it's just on the lowest setting. That is oem bathurst coilovers. Lift the dust boot, if you see orange dust then the bump stops are toast, if you don't, you're good, just raise it up a bit.
May have more abuse but I've never seen or heard of akira lol.
If it's anything though I have seen all the initial d series, most of wangan and a bit of shakotan boogie!
I remember watching FotNS when I was around 14 trying to work out what kind of trip I was on.
The whole shockWhich bit? The dust boots? They just lift up.
