- Feb 10, 2018
Sorting out the fittings needed to pipe up the air con. found a air con place in Warwick that had the two fittings in stock that matched the sizes on the evaporator/blower unit under the dash as the Japanese use a different thread & fitting size to Europe.
Have spent a lot of time pluging in sensors on the engine, cooling & oil system for the Emerald ECU & the two SPA gauges. So ended up under the car getting covered in filler dust form the time the car spent at the paint shop routing wires & clipping them to parts that don't get hot or rotate.
Last job on Saturday was making a start on the air intake, it's a tight fit under the bonnet so had to turn it down immediately out of the throttle body. I've bought a round K&N air filter so just need to turn the pipe at 90 Degrees to run along the top of the radiator.
Getting close to firing it up
so put 3 gallons of fuel in it! that will be the first time since 2010.
