Quick release switchable from bnr32 and fd3s
mangiavelox
I have some cars and I wouldn't purchase many steering wheel for each car 🤣.
My idea is to take 2 quick release and swap the steering wheel from my bnr32 and my fd3s.
Which quick release I need and the version is the same for both cars?
For my bnr32 I have 2 steering wheel, one Nardi and a sparco whith small diameter when I go on track days. All the parts of the quick release will be used.
I'm using an NRG quick release hub for my wheel (keys racing) and an additional shorter column mounted base for the quick release.
If you get an NRG quick release kit, and then the column base for each car it will work - as in using the same wheel on both cars snap on/off etc. NRG have a lot of fitment options and they would work on both cars.
TBH you just need 1.5 quick release kits, one part stays on your wheel and the others stay on the cars, as long as there the same make kit you'll be ok.
Thank you for your reply. I will see for the nrg
