Possible need an old school 1600 secondary!
Mattfdoc
As above my case in the dyno at pips and one of the 1600cc secondary injectors is stuck wide open, he’s having a look to see if he’s got a spare but just incase does anyone have one? Or two?
I am not saying this is your issue here - but I have seen this happened before with a faulty pfc on t0bbbos car, i would suggest swapping the ecu out with another as a quick test before u swap the injectors.
That’s another possible but the injectors have been flow tested today already and one has been found to be faulty, another pair has been found and will be fitted before a possible ECU swap tomorrow if needed 👍
