Pair ms01 10j
Greg87
Hi, anyone got the above available for sale?
Preferably around 35/40/45 et if possible.
I’m guessing it’s a real long shot but would appreciate pictures, price and location
I think @JoeLanger had a full set in bright orange for sale but unsure on offset! I don't think he'd part with just a pair though!
No I don't have 10s
There was a guy selling some on FDUK but they have sold I think.
Why do you want 10s anyway, unless you've got larger arches you're going to struggle to get them to fit without stretched tyres and over cambered. 9s will be fine
I’ve been using the calculator to see what would fit and thought that the 10s would be ok.
My car isn’t lowered or anything (yet).
I was just hoping to get some wider wheels on and didn’t think the extra 1/2 inch on the rear and same on the front would make much difference.
I havent got them exact wheels but Ive got 18" 10j et35 wheels on the rear of my car and its lowered, with an arch roll u shouldnt have a problem fitting .
Hope this helps.
Also ive got an arch roller if anyone needs to come borrow it 🙂
Hope this helps.
Also ive got an arch roller if anyone needs to come borrow it 🙂View attachment 6153
Fitment looks pretty good, if I get a higher offset I shouldn’t have any issues I think.
I don’t plan on going too low either so should hopefully be fine.
Just need to find some now, I would consider a full set of 4 if splitting wasn’t an option.
Think I’m going to have very little luck if there’s only 2 sets in the uk though
10s are fine on the back with a 255/265 in the offset the MS01s come in (I think mine are et38, I can't remember, as I've bastardised them with the centers from a set of 9s to make them lower offset).
If you really want 10s for the dish (it's more than 9s, I'll try and find a picture later for comparison) then if you keep your eyes peeled you may come across a set of 10s from another 2pc Rays made wheel from the 90s, you can swap the centers on a lot of them as the PCD and bolt count is pretty consistent,
It's not the best photo I'm afraid, but these are (left to right) 8s, 9s and 10s in this photo. You can clearly see the difference in the dish. I can't remember what the exact measurements were but I'll try to get some fresh ones.
Iirc the 9s and 10s use the same centres, the 8s have a thinner center section so build into a wheel with a higher offset.
I hope that's not true as I just put my 8s and 9s together! Didnt look any different, pretty sure i checked them. Will have to doubke check them know si.
I think there may be two different offset versions of the 9s, I'm not sure. TBH all the measuring I did was about 5 years ago and I'm a bit hazy. I'm sure u scribbled it down on fduk. I'll go look at some point.
Fuck sake they're all in the loft now. My fronts don't fit over the RZ brakes so this might solve that issue at least!
I guess I’ll try keep my eyes open for a pair/set of 10s. Failing that I’ll try get a set of 9s and a pair of other 10s and make them what I’m looking for.
I was they guy that bought the set on fduk, they fit amazingly well with no work required to fit them. If you can find another set they definitely do a buy!
They’re being used as a resto project I have, just needs a manual conversion, wheel refurb and painting and she’s done.
I might sell mine, not 10s though, 8s/9s
From what’s been said previously I may need a pair of 8/9/10s so I can have the 10s on the rear and 9 on the front but still clear the brakes (mix and match the 8 and 9s)
How much are you looking for them? Got any pictures?
I need to be sensible on what I spend as I’m supposed to be saving for a trip with the family, but if it’s a good price I could be tempted 😄
