Original radio/head unit
Astero
Hi, Looking for an original FD radio/head unit. If it works and you've got one spare after upgrading to a modern radio hit me up! :)
Cheers!
Prob worth saying which type you're after as there quite a few versions over the years.
Also the radio wont work without mods as they use different frequencies in japan.
Cheers for the info guys! I'm after it to fit a UK model 1995 FD, I have no idea what version that'd be.
I heard the mx5 ones fit, but the car is 99% stock so an actual rx7 one would be nicer. Is the mx5 a straight fit or is any modifying needed? I currently have an early 2000s radio in there that's rubbish so an Mx5 may be a good alternative for now.
guess you will just need to sort the wiring but other than that its a double din so will fit, i've been thinking about doing the same
