OEM Sideskirts
I have an original set, will need painting and prep as they are a foam material.
Hi Ben. Thanks for your response. It's a shame that top rear fixing hole is damaged on the passenger skirt. Being the rubber material, i don't think trying to repair will be easy, if possible at all.
Do you have any of the original fixings?
The original fixings weren't reusable, just simple dome head screws and M6 screws on the underside into clip in plastic fixings. I'm sure they are the same as an MX5 part. They are bonded and screwed on and quite hard to remove! I don't know what a body shop would quote to repair, but a flexible epoxy can be used to repair them from what I read.
Otherwise I would look at the Concept 7 ones in fibreglass as an alternative to the OEM.
