No dash lights...
jack.am
I have no dash lights, I'm pretty sure the dimmer switch is broken. Bulbs are all fine. Meter fuse is fine. Before ordering a new one I thought I'd bridge the pins to see if I could just get the lights on full.
Nope. Bridging just seems to pop the 15A fuse for the tail-lights? What's going on there?
What year is your rx?
from a 93 EWD
12-01is the controller
3 wires
red/green
black
red/black?
'93 JDM
I tried bridging r/g and bl - nothing
Briding r/b and bl blows the tail light fuse
If I put +/-12v to pins 2 and 3 on the dimmer switch would I expect to see a variable voltage on pin 1? Or vice versa pin 1 and 3?
I need to go and extract the TNS relay from the retarded place I hid it away and see if it's damaged
😂 ah that's the one I'm gonna try and relocate.
Vmount fitted so had to move it so might put it in the boot like some other mad man on here did.
