New engine first fire & break in tips
sorry to hijak, i didn't find any pills in the vac lines or on the turbo actuators on mine. they're 99 spec, which i'm sure i read the pills were built into the actuators. does this sound right?
They're part of the nipples on the compressor housing on the N3G1 turbos (y).
People often drill out the restriction when fitting a boost controller with the later turbos.
do you mean the vac nipple on the actuator? i don't remember there being a nipple on the compressor housing itself... or am i confusing nipples 🤔
I have N3G1 turbos. Didn't check to see if the nipples had been drilled... 😂
What are the symptoms when boosting if the restrictors have been removed?
Nope, I mean the nipples on the compressor housing where you hook up the pipes that go to the actuators.
bingo. i've found them, that's answered a longstanding search for the hidden pills, thanks 👍
