Lower intake hose - silicon or metal
Jake_rorx7
I'm after a replacement lower intake hose (filter to turbo) that is standard fitment, but in a black silicone or metal.
I have a HKS hardpipe replacement but it is non standard size! NEEDS to be standard fitment.
It’s not really that much of a restriction. I assume we’re talking about airbox to turbo?
From tests I've seen those corrogated hoses are quite restrictive compared to a smooth silicone job. And if someone has an off-the-shelf solution, I wouldnt think it would be too expensive either.
Unsure if useful but could you get something from here?
Possibly, but I'm really trying to avoid cutting two hoses together with a alu joiner in the middle. It would work if there is nothing else available, but I'm looking for a single piece silicone job for the funky double bend.
I actually have a full metal version of the pipe, but its not flexible enough and needs silicone joiners on either end so doesnt actually fit. Autosiliconehoses offer cusom jobs, but I'd have to buy 50, as silicone hose is quite expensive to make the tooling. Not sure I could find 50 people for a group buy!
I'm quite suprised there is no silicone equivilent available for us as a direct swap, basically all vehicles have kits that contain silicone replicas of every intake hose.
Any exhaust fab places nearby? Could take them what you need and ask them to make it up
People usually just go to open filters rather than keep the airbox. I struggled for ages trying to find the same solution as you and gave up, just made some eBay alu pipes and silicone couplers work.
I've got the Petit filter thingy, which is basically two short aluminium pipes about 6 inches long joined together. K&N filters on the end of those, a fabbed heatshield between them and the radiator to keep the hot air away and duct the spare cooler air that slips around the radiator. A hard pipe for the top intake across the turbos, but the lower intake is stock. So everything is nice and free-flowing other than this last piece of the puzzle. But the hard alu pipe meant for the HKS filters doesnt fit.
For the metal pipe? Interresting thought, I may give that a shot. I thought about cutting up the one I have but the angles wouldnt be right, so it would have to be a new part. Cheaper if I buy and cut the pipe for test fits before welding.
