- Jan 21, 2018
Add modern styling and functionality with our discreet rear bumper light. Each light featuring a high output white and red LED and reflector (EU approved) to satisfy legal requirements.
The construction is of solid polyurethane and will be finished in black primer ready to be colour coded.
A 3 wire male and female connector is fitted this will replace the factory plug using a shared common earth (which can be taken from the original loom) along with a positive feed for the reverse light (again supplied in the original loom) leaving the need for a positive feed for the fog light to be installed.
The lights will be supplied with circular vinyl stickers which can be used to cover the reflectors and lenses during painting.
N.B. Care should be taken when handling these lights, they are liable to break if dropped.
LED Rear Bumper Lights
