- Jan 2, 2020
Hi guys
i’m currently doing a fuel line & pump upgrade
Using an8 fittings & 16mm (outer) braided fuel line / single 044 bosch pump/
Injectors 1600cc & 850cc / fitting relay
Running 2x new lines from the engine straight into the tank, but noticed on the return line it’s a filter above the diff. Do I bypass it or fit a another one filter ????
plus what are people doing with the breather pipe coming from the tank? I’ve just had a little air filter sat on top in the engine bay, can you remove the line back to the rear diff & modify it some way?????
Fitting the 850cc in stand rail, where can I get the spacers???
thanks I’m advance
thanks I’m advance
