Front Wheel Arch Liners
Mazda for the arches, nearly all the used ones I've seen are trash, occasionally the undertrays come up for sale
That and the late ones are slightly different to accommodate the different brake ducts and rad angle, so all the parts you require need to be off a '99+ (y).
thanks guys... they are just soooo expensive!!! lol
I defo need some.... photo below
I did not drive the car in this state to cause this I need to clarify lol
Personally, I'd whip that arch off, get that bit treated and painted and then maybe just a small patch of plastic behind the arch liner! If you're that anal about it, you could even get your Stanley knife out, cut the liner and the plastic weld a new patch in and use something like epoxy as a filler to hide the weld!
Mind you, taking another look at the pic, welding a patch in would take some work with that!
