Footwell Leak - Firewall Entry Points?
RichLeeRX7
Hi guys,
I know this question has been asked a hundred times but I believe this is not the usual air con drain (no air con but drain is in place) and the water getting in through old wiper cowl screw inserts as they've all been replaced and sealed.
If I directly place a hose down the wiper cowl baffles/vents that drain down between the firewall inner and outer firewall the water runs into the interior footwells.
Without pulling the dash, what other entry points are there through the firewall that are fairly high up not low down?
I was hoping someone with a shell could take some photos before I end up pulling the dash out.
I'm thinking it could be some kind of seal for the vent system that allows exterior air to flow into the cabin? I'm pretty sure it's running in at a mid point.
Any advice or photos would be appreciated 😎
