Fitting OEM foglights
Efini_Dave
Just got a set of OEM fogs for my FD which I assume came from factory without them
My question is will everything be there to support them? I have the loom for the fogs but I am hoping there will be a plug already existing for it.
Also I need to see if the switch is in place.
Anyone fitted the OEM fogs before?
Pretty sure they were stock equipment so should all be there unless someone has removed, guess the switch may be gone but no reason to remove the wiring
Ok so I've spent tonight looking to fit these and to my surprise to find that the brackets for the fogs already exists along with the plug for the loom and also the plug for the switch is sitting under the console unit, so all that is needed now is a fog light switch...which seem to be very expensive for what they are. (Anyone got one?)
So either Mazda fit everything bar the fogs and switch regardless or someone has previously removed it all.
Just refitted mine, all the wiring was there and the brackets, got them connected up but still cannot get them to work.
I’m hoping it’s a fuse or something that has been removed but following just in case there is more to it
Check the relay is there and working
I tested the plug for the switch and I've got power there but I won't know if my fogs work correctly till I get a switch fitted....will report back when I do.
