For Sale FD OEM and aftermarket parts storage clear out
Update:
2x Front upper control arm - SOLD
2x Rear upper control arm - SOLD
2x Rear trailing arm - SOLD
1x Rear lower control arm - SOLD
Photo album of all the parts: https://ibb.co/album/sbDYnQ
USDM Lower Intake Manifold w/ secondary fuel rail and injectors - $170
USDM Upper Intake Manifold (semi polished) - SOLD
JDM Throttle body with TPS sensor - $275
USED Throttle body Dash Pot zinc coated - $15
2x 1999-2000 ABS pump - $75 each
5x 1999-2000 ABS ECU - $25 each
EU Spec OEM Twin Turbos - $895
USDM Gauge cluster - $820
NEW LHD Throttle Cable FD01-41-660B - SOLD
NEW hose FD01-61-211A - SOLD
NEW hose N3A1-13-691A - SOLD
NEW hose N3A1-13-681A - SOLD
NEW hose FD01-61-214B - SOLD
NEW hose N3A1-13-692A - SOLD
Rear red seats - SOLD
Red roof liner for sunroof car - $320
Rear windshield washer tank with pump - $10
Rear brake line F splitter - SOLD
Early spec ABS Pump seals - SOLD
Door latch covers with Mazda logo - SOLD
RHD brake master cylinder - $25
Master cylinder hard lines - I'll probably just throw these in the trash
Front and rear brake caliper parts - $15
LHD Engine harness - SOLD
Gauge cluster housing - SOLD
Water pump housing - SOLD
Early spec ABS ECU - $25
NEW Carbon fiber exhaust heat shield - SOLD
LHD throttle pedal - SOLD
Glove box hinge bracket - $39
Thermostat housing/waterneck - $25
Underside brace - SOLD
Resistor with zinc coated bracket - SOLD
Brake booster to firewall spacer - SOLD
4.1 stock ratio differential ring and pinion - SOLD
Red rear seat belts - $79
LHD passenger door grip handle - repaired! - SOLD
Red rear quarter panels for rear seats - SOLD
Stock exhaust manifold - $32
Stock rear USDM bumper - original silver paint - SOLD
Stock rear taillights - $395
Parcel shelf - Bose - SOLD
Stock/KYB struts - SOLD
NEW mounting brackets for halogen light for early spec bumper - $15
Stock turbo and exhaust manifold heat shields - $25
Stock Bose acoustic wave tube - $139
LHD power steering cooling line - Will throw away
4x 16" stock Mazda FD wheels - $485
OEM Oil and Coolant gauges - $15
Injector Connectors - SOLD
Stock coils - SOLD
Trunk plastic trim bracket - SOLD
Trunk plastic trim left and right - SOLD
FD Spare tire - $69
94+ Rear subframe braces - SOLD
Stance Parts Air Cup Complete Kit - SOLD
Oil pan braces - $117
RE-Amemiya Super Door Mirrors carbon fiber - SOLD
Turbosmart eBoost 40 street - $260.00
Selling OEM Twin Turbos (from early spec EU car) - excellent condition/low mileage
NO shaft play in any direction, NO manifold cracks
PORTED wastegate.
All metal gaskets in good condition (none are cracked)
Manifold flange surfaces professionally sanded flat.
