Engine ancillaries and gaskets
Efini-dan
I'm after a list of parts,
Manifold gaskets - exhaust and upper inlet
Alternator
Starter motor
Oil filter pedestal
Water pump/thermostat housing gaskets
Power steering pump and bracket
Engine bay heater hoses
Oil level sensor
Water level sensor
No doubt there's more but that's what I can think of at the moment.
Thanks.
I have a stock starter motor somewhere, removed it for a re-housed RX-8 one and it was working fine when taken off. Shipping will be expensive though, it can be collected from either East Mids or North Kent if you're ever in either of those areas?
Also water level sensor... I've been trying to make one of these to replace my fucked one, all you need is a nylon M10x1.25 bolt (easier said than done) drill it out, thread in a smaller diameter, longer steel bolt and put a ring crimp on the end. To buy them new from Mazda they're about £100.
Thanks dude, I've already managed to source those bits now.
Great idea with the sensor btw.
