Double Gauge Pod
Concept 7
The Concept-7 gauge pod base uses the same fastening points as the OEM centre speaker. It fits into place quickly and easily after simply removing the centre speaker grill and speaker itself.
The top housing has been shaped to fit the contour of the FD dash perfectly, and two allen bolts secures it quickly to the base.
Construction is of fibreglass and has a glossy black gel coat finish. Textured finish can be offered as an option.
Available for 52mm and 60mm gauges.
Double Gauge Pod
