- Jan 8, 2018
Big thanks to Scott for gathering this info and allowing it to be shared
Just found this on the RX7 Forum in the States, very good info for the plug connectors
http://www.rx7club.com/3rd-generation-specific-1993-2002-16/fd-harness-connector-list-part-s-984160/
And here is what i did and managed to find to build my new loom
Contact Chris Ludwig For the CAS/RPM and TPS Connectors. He also has the Denso Injector Clips if you need them, all come with pins. (See below for alternative Sumitomo connectors)
ludwigmotorsports@insightbb.com
http://www.lms-efi.com/sunshop/index.php?l=product_list&c=20
Sumitomo Connector pins. These are used in the CAS plugs, Injector Plugs, the 2 no. Grey Transmission 2 pin Harnesses, and TPS connector. These are only the female ones i'm talking about from the Main Engine Harness.
Pins: http://www.bmotorsports.com/shop/product_info.php/cPath/109_110/products_id/1783
Rubber inserts: http://www.bmotorsports.com/shop/product_info.php/cPath/109_110/products_id/681
The TE/AMP connectors for the ECU Connector Blocks and all the Pins are suprisingly available at RS Components.
The only ones i couldn't find or have been discontinued are the blue 10 pin connector and the white 14 pin connector (the one that connects to the dash loom)
Small Connector Pins: RS Components Ref: 712-1909
Larger Connector Pins: RS Components Ref: 680-5088
26 Way ECU Connector Block: RS Components 712-2494
16 Way ECU Connector Block: RS Components 720-1042
22 way ECU Connector Block - RS Components 720-1058
12 way ECU Connector Block - RS Components 720-1036
Shield Cables
Knock Sensor & O2 Sensor Cable
http://rover.ebay.com/rover/1/710-5...0001&campid=5338477309&icep_item=190366069818
CAS/RPM
http://rover.ebay.com/rover/1/710-5...0001&campid=5338477309&icep_item=190368026409
All the other Connectors (apart from the IAC white one which i have no idea what is) are Econoseal J Mark II.
Female Pins available again at RS Components Code 679-5063 (10 Pack)
Rubber Wire Seal to go with the pin RS Components Code 680-6949 (10 Pack)
Thermostat and Fuel Temp Connectors Plug (Green Plug)
Connector: RS Components Ref: 712-1337 (min 5 Plug Order)
Pins same as above i.e.
Standard MAP Sensor Plug
Connector: RS Components Code: 680-6970
Yellow Lock Plate: RS Components Code: 712-2154
Pins as above i.e.
OMP Plug
Connector: RS Components Code: 718-7274
Yellow Lock Plate: RS Components Code: 717-4319
Pins as above i.e.
Bosch and some other Fuel Injector Clips. Also for the Fast Reacting Air Temp Sensor
http://www.efi-parts.co.uk/index.php?productID=139
*NEW - UPDATED 24/11/14*
ALTERNATIVE SITE FOR SUMITOMO CONNECTORS :- http://www.easternbeaver.com/Main/Elec__Products/Connectors/Sealed/SMDL/smdl.html - These also have the 8 way connector for the Igniter if you want it.
New Alternator connector - Standard Mitsubishi Alternators
http://rover.ebay.com/rover/1/710-5...0001&campid=5338477309&icep_item=271533419759
OR
http://store.alternatorparts.com/partnoc1900.aspx
** UPDATE 05/12/14 **
For the blue fuel pump connector on the standard hanger which connects to the top cover from the pump, you can depin this and use these pins. They click into place just fine, so you can then use a thicker cable for instance if you have an 044 in tank. Make sure you use a fuel resistant cable.
http://rover.ebay.com/rover/1/710-5...0001&campid=5338477309&icep_item=161470778271
Shield Cables
CAS/RPM
Pins as above i.e.
OMP Plug
Pins as above i.e.
OR
