Connector Plugs (Thanks to SmbFD3s)
suiteproductions
Big thanks to Scott for gathering this info and allowing it to be shared
Just found this on the RX7 Forum in the States, very good info for the plug connectors :)
http://www.rx7club.com/3rd-generation-specific-1993-2002-16/fd-harness-connector-list-part-s-984160/
And here is what i did and managed to find to build my new loom :)
Contact Chris Ludwig For the CAS/RPM and TPS Connectors. He also has the Denso Injector Clips if you need them, all come with pins. (See below for alternative Sumitomo connectors)
ludwigmotorsports@insightbb.com
http://www.lms-efi.com/sunshop/index.php?l=product_list&c=20
Sumitomo Connector pins. These are used in the CAS plugs, Injector Plugs, the 2 no. Grey Transmission 2 pin Harnesses, and TPS connector. These are only the female ones i'm talking about from the Main Engine Harness.
Pins: http://www.bmotorsports.com/shop/product_info.php/cPath/109_110/products_id/1783
Rubber inserts: http://www.bmotorsports.com/shop/product_info.php/cPath/109_110/products_id/681
The TE/AMP connectors for the ECU Connector Blocks and all the Pins are suprisingly available at RS Components.
The only ones i couldn't find or have been discontinued are the blue 10 pin connector and the white 14 pin connector (the one that connects to the dash loom)
Small Connector Pins: RS Components Ref: 712-1909
Larger Connector Pins: RS Components Ref: 680-5088
26 Way ECU Connector Block: RS Components 712-2494
16 Way ECU Connector Block: RS Components 720-1042
22 way ECU Connector Block - RS Components 720-1058
12 way ECU Connector Block - RS Components 720-1036
Shield Cables
Knock Sensor & O2 Sensor Cable
http://rover.ebay.com/rover/1/710-5...0001&campid=5338477309&icep_item=190366069818
CAS/RPM
http://rover.ebay.com/rover/1/710-5...0001&campid=5338477309&icep_item=190368026409
All the other Connectors (apart from the IAC white one which i have no idea what is) are Econoseal J Mark II.
Female Pins available again at RS Components Code 679-5063 (10 Pack)
Rubber Wire Seal to go with the pin RS Components Code 680-6949 (10 Pack)
Thermostat and Fuel Temp Connectors Plug (Green Plug)
Connector: RS Components Ref: 712-1337 (min 5 Plug Order)
Pins same as above i.e.
Standard MAP Sensor Plug
Connector: RS Components Code: 680-6970
Yellow Lock Plate: RS Components Code: 712-2154
Pins as above i.e.
OMP Plug
Connector: RS Components Code: 718-7274
Yellow Lock Plate: RS Components Code: 717-4319
Pins as above i.e.
Bosch and some other Fuel Injector Clips. Also for the Fast Reacting Air Temp Sensor
http://www.efi-parts.co.uk/index.php?productID=139
*NEW - UPDATED 24/11/14*
ALTERNATIVE SITE FOR SUMITOMO CONNECTORS :- http://www.easternbeaver.com/Main/Elec__Products/Connectors/Sealed/SMDL/smdl.html - These also have the 8 way connector for the Igniter if you want it.
New Alternator connector - Standard Mitsubishi Alternators
http://rover.ebay.com/rover/1/710-5...0001&campid=5338477309&icep_item=271533419759
OR
http://store.alternatorparts.com/partnoc1900.aspx
** UPDATE 05/12/14 **
For the blue fuel pump connector on the standard hanger which connects to the top cover from the pump, you can depin this and use these pins. They click into place just fine, so you can then use a thicker cable for instance if you have an 044 in tank. Make sure you use a fuel resistant cable.
http://rover.ebay.com/rover/1/710-5...0001&campid=5338477309&icep_item=161470778271
96+ ECU connector part no's (These fit my S6 PowerFC and S8 Adaptronic Modular for my 99 spec car) :
28 Way ECU Connector Block: RS Components 720-0935
16 Way ECU Connector Block: RS Components 720-0923
22 way ECU Connector Block - RS Components 720-0932
34 way ECU Connector Block - RS Components 720-0939
http://www.ebay.co.uk/itm/10-x-Sumi...arts_Vehicles_CarParts_SM&hash=item2598688b9f
Has anyone depinned and replaced the wire from the connector when you run a fresh 12v to the connector on the outside (boot side) of the fuel pump? Anyone know if these pins will work?
The ecu connector pins for the 16bit ecu are different to the ones listed (712-1909) they do fit but do not lock in place unless the lock tab/plate is pushed in.
The correct pins for the 16 bit ecu’s are 680-5097.
Feel your pain, I made 2, found most connectors but there was 2 connectors I never managed to source
Anyone found the plug for 99 engine loom to ecu plugs links please
I think a couple of them are discontinued or at least on large min order quantities.
These are the plugs for the 99 spec engine loom. I'm pretty certain the socket was available but not got the part no to hand. The 22 way connector I can now only find with min order qty of 1000 units for £2,580.00
28 Way ECU Connector Block: 316019-6
RS COMPONENTS: TE Connectivity, MULTILOCK 040 Pair Mate Male Connector Housing, 28 Way, 4 Row
MOUSER: TE Connectivity, MULTILOCK 040 Pair Mate Male Connector Housing, 28 Way, 4 Row
16 Way ECU Connector Block: 316013-6
MOUSER: TE Connectivity, MULTILOCK 040 Pair Mate Male Connector Housing, 16 Way, 4 Row
22 way ECU Connector Block: 316016-1 (min order qty 1000) or 316016-6 (min order qty 2000)
MOUSER (316016-1): TE Connectivity, MULTILOCK 040 Pair Mate Male Connector Housing, 22 Way, 4 Row
MOUSER (316016-6): TE Connectivity, MULTILOCK 040 Pair Mate Male Connector Housing, 22 Way, 4 Row
34 way ECU Connector Block: 316022-1 or 316022-6
MOUSER: TE Connectivity, MULTILOCK 040 Pair Mate Male Connector Housing, 34 Way, 4 Row
