Charge control actuator
tested it at work today with 10psi in the chamber B (back chamber) simulating primary boost. and then switched from vac to pressure on chamber A (front) and the flap doesn't open fully till around 15psi which surely cant be right ?
It works from vacuum 👍
So it's in closed position under vacuum then when it sees any pressure from 0+ the door swings open 👍 the easiest test for charge control is engine on engine off 👍
I'm 99% sure on this but I'm sure someone will confirm! We are talking about the actuator on the y pipe/secondary turbo side right?
yea ive seen that it works from switched vacuum and pressure it has vac to keep it closed and then its supposed to be switched by the solenoid to pressure which is then supposed to open the flap but if mine is taking 15psi to open fully surely this isn't right as chamber B will always have around 10psi when the primary turbo is boosting.
yea I assumed this wasnt right and as you said as soon as it sees any pressure +0 it should open I was hoping to find another actuator to test and see if it did the same thing.
