99 spec front end
welshkid
Thinking of going the typical 99 spec route, anyone got any recommendations on where to pick the bits up?
I want to do it fairly "properly" from what I can tell I'd need:
Bumper
Lip
Re-bar/support
brake and oil cooler ducting
undertray (Is there anything to be careful of if going v-mount?)
99 spec lights or maybe car shop glow ones
Loom/adapter for 99-spec light?
Assorted fixings/brackets? (Assuming its a fairly straight forward fitment).
think muz at japwest mods has a bumber,
advocult do a lip,
concept 7 do oil cooler ducting,
just chop your support down to fit,
if you go down the csg route the fitting is for the early models, no need for adapters.
hope that helps
properly will cost ya about £1500 :)
A bit more than that I'm afraid, I'd say probably closer to the plus side of £2k with paint etc.
£700 for Bumper and Splitter
£600 Rebar
£348 Stanleys
£180 Brake/Oil Ducts
This does not include import duty or shipping.
I added:
£120 Concept 7 Oil cooler Ducts.
You DO NOT need the 99 spec undertray. The pre 99 fit's with only two holes needing drilled for the brake/oil cooler ducts. If you do not want the fin sticking up on the center piece you simply drill out the plastic rivets and remove it.
£600 Rebar
£348 Stanleys
I added:
Also don't need rebar either, early one is easily modified to fit. I picked up Stanleys for £100 in good condition used, I believe URAS ones are an affordable option too.
I agree, you can get other options to cut the costs down, I also forgot to list the air divertor for the 99 bumper / rebar. £70.
