Wiper motor
Efini-dan
Looking for one that works as it should please as mines gone so tired it won't sweep one wiper let alone two.
Thanks.
It might be worth checking the mechanism as sometimes the wiper arm spindles can gum up and be a cause of it going slow as well. Also the power goes through the stalks so that might prevent the motor seeing the full voltage.
I have a similar issue with my wipers going slow and sometimes stop if the windscreen is dry, I still need to check the voltage the motor sees.
Yeah I replaced the linkage thinking it was that but it wasn't so like you said it's either not getting full voltage or it might actually be the motor. The car was sat for years before I had it and has sat a few more in my ownership.
Stock J-spec wiper motor is very poor at the best of times. Above around 80mph it starts to slow down and at about 125mph will completely stall on the upward stroke. I fitted a couple of relays (1 for each speed) to at least remove the resistance in the wiring/controls. Made an appreciable difference. Think they keep going to about 150mph now, but will stall if left on intermittent/slow. Only downside is when used on intermittent, they park very slightly high.
No problem regarding the linkages, I found that the spindles on mine didn’t move freely. I ended up taking them apart, cleaning and re-lubricating the bearing material, it helped but still not great.
You do 150 in the rain driving an RX7!?! Your balls must be like mangos 😆
