The DIY tuners : compression testing video
Ste
Good evening guys
Thought I would share my latest video where I compression test my car using a piston tester and a twisted rotors tester. Both were quite similar with the piston tester showing around 7bar - 100 psi before normalising and the rotary tester showing around 99.
I also got good results which is always nice
Let me know what you think all comments and likes are appreciated as more interaction helps promote the channel with the YouTube algorithm
You can get to your plugs from on top?? Wheres you pas pump gone lol?
Love stuff like this, I've subbed - I've been wanting to start a channel with a mate, but really haven't pulled our fingers out lol.
Yep I don't have pas pump or aircon so I've put my alternator down there 😂. But even standard cars I've tested I don't take aanything off.
Just start it now otherwise you never will. You don't need a fully polished set up at first you need to do it to learn. And it takes so long to build momentum
