Tein coilover spring, front
Jake_rorx7
Hi all
Failed MOT on a coilover spring snapped.. does anyone have a spring, or a used front shock I can replace from the Tein kit? Need it ASAP to get her on the road again
Cheers
PS I have no idea which kit this is, are the springs interchangeable? Can I use the lowering spring kit to replace one spring?
Springs all vary in size and spring rates... U need the overall uncompressed length. I have various springs but you need to put back in what comes out...also your collars are likely to be seized so you will.need a spring compressor to put back in...find out what type you have, flex, superstrret etc
Thanks, I was very kindly given a pre-loved set of coilovers to repair my 7 with so I dont need a spring/coil anymore :)
