If you wanna go cheap I have a Greddy t78 and Greddy 50mm Wastegate. Turbo has no play and runs nice. £450
Will be about 5-800 rpm slower spool than the bigger one I listed but will easy make 500whp.
cheap manifold or a Greddy one as they pop up quite frequently for £250ish. You are gonna have to go custom downpipe 95 percent of the time when piecing a single turbo kit.
Kind of power does the t78 make, what rpm are we talking for full boost, it's mainlyn for track application so not being below 3k is not an issue really.
It’s good for 600whp if pushed.
20 psi should see around 500whp. Full boost around 4200rpm. Google it. There must be 10000 threads about this turbo on an Rx7.
