Oil cooler setup
Enigmatic Ed
Hey guys, after a complete aftermarket oil cooler setup as the oem one came apart at one of the connections causing engine failure due to no oil. Engine done less than 400 miles hooray. Thanks.
I have a mishimoto dual pass 19 row cooler, single centre mount with local thermostat for sale from my build. Has HEL AN10 braided hoses and fittings throughout, coat £600 to build, the hoses and fittings were more than the cooler lol. I have it centre mounted but it would side mount or could be incorporated to a v-mount or stock set
Can be seen in pic, if you’re interested or need more pics give me a shout
I’d be happy To let it go for £300
10784
Boo. We have been talking about putting rx8 oil coolers on! Someone done it a few weeks back and said it's worked! Not sure if you'd wanna go that route?
This is the discussion
I hve two 30 row coolers with brackets that I made to mount each side, never got round to doing lines etc
I've got two setrab 25 row coolers and a mishimoto thermostat. I made the brackets myself using some 1mm aluminium bar and some 15mm rubber mounts.
Don't scrimp on hose or fittings either.
Don't buy mocal oil coolers unless it's the high pressure hard core version they sell.
