- Apr 26, 2018
Hey all,
I know this topic is extensively covered but just wanted to share my experience installing these blind BEFORE reading all the threads on here:
I bought these Philips Ultinon Pro3021 LED Car Headlight Bulb (H4) blind off Amazon for £45: Here
They fit with only minor modification of the rubber headlight bulb cover.
I did this with a spare set of covers by turning them inside out, feeling where the rubber goes slightly thinner from the 'threaded' inner and drilled a small hole.
Then took a sharp blade and cut the thick centre to meet this hole.
The heatsink now fits through this and provides a reasonable seal.
The bulbs need fitting in the headlight with the covers on, and this is fiddly but can be done with some practice.
The bulb retention clips need moving around the bulb, which can be difficult but does work.
These are almost fully plug and play and much cheaper than some of the other options i've seen reccomended.
Of course the modification to the cover means the seal wont be watertight, but i can handle that.
They clear the headlight basket and plug right in.
