modern ECU , didgidash, PDM
Kit like this:
Instructions:
Use the things you definitely need (lights wiper etc), leave the engine running stuff weeeeeeelllll alone
OK looks like you have alot more than I was presuming but that's a pretty thorough job on stripping stuff out that you'd required for the road.
I more agree with rx_dreamer and Jit in just grabbing stock looms and a working dash. You don't really need a new ECU but connecting a digi dash to the apexi is probably a pain, whereas stock clocks should be alot easier.
new stock looms, then link and a display connected by can.. job done for simplicity buddy. And out the display on the mounts you can buy for it 👍🏻
Kit like this:
Instructions:
thanks for this : )
thanks, Pro4m are supplying Haltech and Halech loom, Apexi is a pain to link to digidash and I have no dashboard so OEM clocks will look a bit odd - haltech too digital dash should be easy enough, thank you
